gps 307
  • xenon
    • 284
    gps 307
    bonjour je possede une 307 hdi 136ch annéé 2004 qui ne possede pas de gps je voudrai en mettre un est ce possible
    GENRE DE PRODUIT VEHICULE PARTICULIER
    MARQUE COMMERCIALE, TYPE ORGANE PEUGEOT
    LIGNE DE PRODUIT 307
    SILHOUETTE BERLINE 3PTES
    FINITION XSI
    MOTEUR DIESEL TURBO DW10BTED4 FAP
    TRANSMISSION BVM6
    TYPE DE PEINTURE PEINTURE METALLISEE VERNIE
    COULEUR DE CAISSE EZW - PEINTURE GRIS FER
    TYPE D’HABILLAGE INTÉRIEUR MAILLE SPEED’UP + CUIR CLAUDIA "SG"
    COULEUR DE GARNISSAGE "FX"
    BOITE DE VITESSES (CARACTÉRISTIQUES) BVM ML6 CL
    MOTEUR (TYPE) MOTEUR TYPE EW/DW
    MONOGRAMME COMPLÉMENTAIRE, DIVERS SANS MONOGRAMME COMPLEMENTAIRE
    MONOGRAMME HDI
    FINITION XSI
    DIRECTION DIRECTION ASSISTEE VARIABLE
    COUPLE TACHYMÈTRE SANS C T
    MULTIPLEXAGE MONTAGE MULTIPLEXE CAN VAN
    ALARME ANTIVOL SANS ALARME ANTIVOL
    APPUI-TÊTE ARRIÈRE APPUI TETE AR REGLABLE
    APPUI-TÊTE AVANT APPUI-TETE AV ARTICULE
    ASSISE ARRIÈRE BANQUETTE SEPAREE RABATTABLE
    ASSISE SUPPLÉMENTAIRE SANS ASSISE SUPPLEMENTAIRE
    ACCOUDOIR ASSISE ARRIÈRE AVEC ACCOUDOIR AR
    BAGUETTE PLANCHER DE CHARGE SANS BAGUETTE PLANCHER CHARGE
    CACHE-BAGAGES AVEC CACHE BAGAGES
    CEINTURE DE SÉCURITÉ ARRIÈRE CEINT SECU AR 3 ENROULEURS 3 PTS
    CEINTURE DE SÉCURITÉ AVANT CEINTURE PYROTECHNIQUE AVEC ALARME
    CLIMAT (TEMPÉRATURE AMBIANTE) PAYS TEMPERES
    GRADUATION VITESSES GRADUATION EN KM/H
    CONDITIONNEMENT RADIO ALIMENT ANTENNE RECEPTEUR HP AV/AR TWEETER
    COTÉ DE CONDUITE (POSTE DE CONDUITE) CONDUITE A GAUCHE
    CHAUFFAGE ADDITIONNEL CHAUFFAGE ADDITIONNEL AUTOMATIQUE
    EQUIPEMENT PLANCHE DE BORD PLANCHE DE BORD STANDARD + FACADE ALU VIF ARGENT
    VARIATION D’HABILLAGE D’ÉQUIPEMENT INTÉRIEUR VOLANT POMMEAU SOUFFLET CUIR
    HAUT-PARLEUR 4 HP AV (2 TW + 2 AV) + 2 HP AR
    COMMANDE D’AUTORADIO CDE AUTO-RADIO A DISTANCE SANS FONCTION CD
    ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) SANS STORE AR
    REHAUSSE ASSISE AVANT PASSAGER REHAUSSE ASSISE AV PASSAGER REGLAGE PARALLELE
    RÉGLAGE ASSISE AVANT CONDUCTEUR MAINTIEN LAT FIXE CONDUCTEUR
    RÉGLAGE ASSISE AVANT PASSAGER MAINTIEN LAT FIXE PASSAGER
    RABATTEMENT ASSISE AVANT CONDUCTEUR AVEC RABATTEMENT ASSISE AV CONDUCTEUR
    RABATTEMENT ASSISE AVANT PASSAGER AVEC RABATTEMENT ASSISE AV PASSAGER
    ACCOUDOIR ASSISE AVANT MONTAGE SANS ACCOUDOIR AVANT
    INDICATEUR DE TEMPÉRATURE EXTÉRIEURE INDICATEUR TEMPERATURE EXT
    COMPACT DISQUE SANS MONTAGE COMPACT DISQUE
    BOITE DE RANGEMENT SANS BOITE DE RANGEMENT
    SYSTÈME DE NAVIGATION SANS SYSTEME NAVIGATION
    LÈVE-VITRE ARRIÈRE SANS LEVE VITRE AR
    LÈVE-VITRE AVANT CONDUCTEUR LEVE-VITRE AV CONDUCTEUR CDE SEQUENTIELLE
    LÈVE-VITRE AVANT PASSAGER LEVE-VITRE AV PASSAGER CDE SEQUENTIELLE
    AFFICHEUR AFFICHEUR (RADIO+MONTRE+ET OU T°,CD)
    MIROIR DE COURTOISIE CONDUCTEUR+PASSAGER OCCULTABLE AVEC ECLAIRAGE
    INDICATEUR D’HUILE RECEPTEUR NIVEAU HUILE
    MONTAGE APPUI-TÊTE ARRIÈRE MONTAGE 3 APPUI-TETE AR
    NAPPE CHAUFFANTE SIEGE NON CHAUFFANT
    SAC GONFLABLE LATÉRAL AVANT SAC GONFLABLE LATERAL THORAX + RIDEAU
    SAC GONFLABLE PASSAGER SAC GONFLABLE COTE PASSAGER
    LÈVE-VITRE ÉLECTRIQUE (FONCTIONNEMENT) ANTI PINCEMENT CONDUCTEUR + PASSAGER
    ORDINATEUR DE BORD AVEC ORDINATEUR DE BORD
    PACK ÉQUIPEMENT SANS PACK EQUIPEMENT
    RÉTROVISEUR EXTÉRIEUR RETRO EXT CHAUFFANT
    NEUTRALISATION COUSSIN GONFLABLE NEUTRALISATION MANUELLE COUSSIN GONFLABLE
    COMMANDE INTÉRIEURE DE PORTE (ASPECT) COMMANDE INT PORTE ASPECT VIF ARGENT
    PROTECTION POSTE AVANT SANS PROTECTION POSTE AV
    RANGEMENT (POSTE CONDUITE) RANGEMENT CONSOLE AV PAVILLON
    RÉCEPTEUR RADIO SYSTEME AUDIO COMPACT DISC RDS "RD3"
    RÉFRIGÉRATION REFRIGERATION AUTOMATIQUE
    RÉGULATEUR DE VITESSES SANS REGULATION VITESSE
    REHAUSSE ASSISE AVANT CONDUCTEUR REHAUSSE CONDUCTEUR REGLAGE PARALLELE
    RÉTROVISEUR INTÉRIEUR RETROVISEUR INT JOUR-NUIT ELECTROCHROME
    SAC GONFLABLE CONDUCTEUR SAC GONFLABLE COTE CONDUCTEUR
    RANGEMENT VOLUME CHARGEMENT AVEC FILET DANS COFFRE
    DÉTECTION D’OBSTACLE SANS DETECTEUR OBSTACLE
    ADAPTATION GARNITURE POMMEAU LEVIER VITESSE+SOUFFLET CUIR
    SURTAPIS AVEC SURTAPIS
    AMPLI-ÉQUALISEUR SANS AMPLI EQUALISEUR
    COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION
    VITRE CUSTODE (NATURE) VITRE CUSTODE PIVOTANTE
    VITRE (TYPE) PARE-BRISE ACOUSTIQUE SAUF SINGAPOUR
    VOLANT VOLANT CUIR 3 BRAS
    VENTILATEUR 1 VENTILATEUR 2 VITESSES 130WAERO
    PACK RADIO / INFORMATION / COMMUNICATION RADIO CD / INFO 2
    SAC GONFLABLE GENOUX CONDUCTEUR SANS SAC GONFLABLE GENOUX CONDUCTEUR
    voila ce que je voudrai monter si possible bien sur il provient d'une 307 annéé 2006
    le poste je pense que oui car il ressemble fortement a la photo celui avec la fleche rouge
    merci d'avance
    Cordialement Xenon
    • 2121
    ta 307 de 2004 phase 1 est en VAN donc il te faut un autoradio GPS pour le VAN!!
    tu ne pourras pas monter un gps de 2006 qui est en CAN!!
    un RT3 en VAN il te faut !
    • xenon
      • 284
      Envoyé par maxime
      ok merci mais pour le gps il faut un branchement speciale ou pas ??? au niveau bsi ou autre chose comme elle n'est pas equiper d'origine
      Cordialement Xenon
        • 2121
        voilà un très bon tuto pour tout savoir sur cette opération:
        Peugeot 307 - Voir le sujet - [Tutoriel] Installation RD3 vers RT3 307 CC VAN - Forum Peugeot 307 - 307CC - 307SW
        c'est faisable mais beaucoup de boulot,du temps et un peu d'argent !!
