FLEX - Outil de programmation MagicMotorsport TCU + ECU - OBD / Banc / Boot
  • Aleksey-MS
    • mars 2021
    • 1515
    Flex MagicMotorsport - Best Chip Tuning Tool
    Hardware
    Flex ChipTuning tool (programmer for ECU, TCU) - $1320
    Flex is the tool that allows you to remap, update and repair ECUs and TCUs for cars, bikes and trucks. With Flex you have everything you need to start working in the world of chiptuning and boost your business.
    The programmer supports all available connection modes. You can easily connect to most of the car ECUs via the vehicle's OBD port. While, for more advanced jobs, BDM, Bootloader and JTAG modes are also possible.
    What inside:
    Cabling kit: FLX3.5 color coded wiring harness
    Adapter kit: 6 pcs set of pin adapters to FLX35
    FLEX Base Module
    FlexBox Module for FLEX
    Connection cable OBD: FLEX to CAN/Kline RED
    Connection cable OBD: FLEX to ENet GREEN
    Connection cable: FlexBox port C to NEC 7F00 XX
    Connection cable: FlexBox port D to BDM MPC5xx
    Connection cable: USB 2.0 AM-BM BLK 1.8m
    FlexBox port E 40 pin adapter for FLK35
    FLEX & FlexBox diagnostic adapter
    Switch Mode Power Supply for FLEX with plugs
    FLEX Branded Box
    MAGBench BDM + Jig Tool Kit - $635
    It allows you to make stable connections with engine control units and automatic transmission units in Boot, JTAG and BDM modes.
    Software
    Full Flex Master - $5390
    Full Flex Slave - $1815
    OBD + Bench Flex Master - $2640
    OBD + Bench Flex Slave - $990
    Flex Full Master software package puts at your disposal all the protocols available for the more than 25,000 vehicles supported by Flex, also make you able to program in the three connection modes.
    Flex Full Slave supports more than 9,000 vehicles and users can rely on the release of new SW protocols by MMS.
    OBD + Bench Flex Master is the ideal solution for each tuner who want to have all the protocols for engine ECUs of cars, motorcycles and vans in OBD and Bench mode. Modify and recalibrate using the Flex programmer without the need to open the electronic unit.
    If you need it to write me for details.
    Dernière modification par Aleksey-MS, 04 mars 2024, 22h04.
    Je peux aider à installer un logiciel de diagnostic automobile
  • Aleksey-MS
    • mars 2021
    • 1515
    Added new kits for this chip tuning tool.
    • Aleksey-MS
      • mars 2021
      • 1515
      New updates:
      Added (for Porsche vehicles with hybrid engines: Porsche Cayenne S (958) 3.0L 422PS and Porsche Panamera (971) 3.0L 461PS):
      Porsche Bosch BMS Read/Write/Checksum Calculation Internal Flash, Read/Write Internal EEPROM, Full Backup
      Porsche Bosch INVCON2.1 Read/Write/Checksum Calculation Internal Flash, Read/Write Internal EEPROM, Full Backup
      All Bosch MSE6.0 MPC5634 Read/Write/Checksum Calculation Maps
      CF Moto Bosch US6.0 MPC5634 Read/Write/Checksum Calculation Maps
      All Bosch MSE8.0 SPC572 Read Internal Flash, Write/Checksum Calculation Maps
      Bug fixes:
      Added support for new type of VAG Bosch MG1CS001 SPC
      Added new CRC type for Fiat Bosch ME7.3.1
      Fixed CRC type for Ford Continental EMS22xx
      Added new CRC type for All Continental M3C
      Added new CRC type for Ford Bosch T93
