Diagbox 7.77 (8.13) Update (en français)
  • Simple
    • août 2015
    • 253
    Upgrade to DiagBox v7.77 (if you have upgraded to 7.76)
    Please notice that this is intended for educational purposes and that you perform any or all the below procedures at your own risk. I hold no responsibility for any issue you may face.
    Procedure (Offline Update):
    1- Go to C:\AWRoot\bin\fi\ and create another copy of cache folder naming it cache.org.
    2- Download the attached "updt_77u.zip" file, Expand it and copy the contents of the updt_77 forder to C:\AWRoot\dtwr\updt\ directly, replacing and overwriting existing files and folders.
    3- Run DiagBox, it will start the upgrade process, when it finishes successfully click ok, it will run for the first time and will give 6 or 7 error message, keep clicking ok until DiagBox closes down.
    4- Copy the 13 files that start with “fr.actia.AWF.xxxxxxx.dll” from cache.org into the (empty) "C:\AWRoot\bin\fi\cache\" folder.
    5- Run DiagBox and it will run successfully.
    If you don’t like 7.77 update or you have an issue with it. Run Maitresox’s 7.74 to 7.76 again and it should successfully downgrade it to DiagBox v7.76.
    DiagBox can be used in any of the 20 available languages (tested on v7.76 and v7.77) and this is how to do it:
    1- For DiagBox:
    - Open the File Explorer and navigate to "C:\AWRoot\dtrd\trans\", find the file "Language.ini" and create a copy "Language.ini.org".
    - Open the file Language.ini and under [LANGUAGE], change "Current=en_GB" to "Current=fr_FR" and save (I commented the original and added the new line to activate the French language).
    [LANGUAGE]
    ;Current=en_GB
    Current=fr_FR
    2- For Lexia:
    - Navigate to "C:\APP\LEXIA\EXE\" find the file "langue.ini" and create a copy "langue.ini.org".
    - Open the file "langue.ini" and under [DicoMap], change all "%LG%" to FR (I commented the original 4 lines and added changed 4 lines to change Lexia's language to French).
    [DicoMap]
    ;CITACT=..\Dico\CITACT%LG%.dbz,APV
    ;CITTT=..\Dico\CITTT%LG%.dbz,APV
    ;CITTV=..\Dico\CITTV%LG%.dbz,APV
    ;THESAU=..\Dico\THESAU%LG%.dbz,APV
    CITACT=..\Dico\CITACTFR.dbz,APV
    CITTT=..\Dico\CITTTFR.dbz,APV
    CITTV=..\Dico\CITTVFR.dbz,APV
    THESAU=..\Dico\THESAUFR.dbz,APV
    - Navigate to "C:\APPLIC\LCTLEX3\", find the file "Dico.txt" and create a copy named "Dico.txt.org".
    - Open the file "Dico.txt" and change the line "Dico=THELEXGB.DBZ" to "Dico=THELEXFR.DBZ" changing from English to French.
    ;Dico=THELEXGB.DBZ
    Dico=THELEXFR.DBZ
    3- For PP2000:
    - If you wish to change PP2000, Navigate to "C:\APP\OutilRep\exe\", find the file "Dico.txt" and create a copy named "Dico.txt.org".
    - Open the file "Dico.txt" and change the line "Dico=THESAUFR.DBZ" to "Dico=THESAUGB.DBZ" to change to English,
    ;Dico=THESAUFR.DBZ
    Dico=THESAUGB.DBZ
    The language change is achieved by replacing the "**" in "Dico=THESAU**.DBZ" with 2 letters representing the language you want, you can choose any of the 20 available languages.
    You can also use a script to change "en_GB" to "fr_FR" but be careful, because some listing are definitions for languages like Arabic or German etc.. But if you dont care and other languages are not needed, I think it will work.
    Language table added
    You can also use the attached Country Codes table to change the codes in your system, example for English:
    Codes for DiagBox (DBX) go into C:\AWroot\.... in (2 Chrs.) statements such as "LauncherEN.DBZ" or (5 Chrs.) statements such as "Current=en_GB"
    Codes for Lexia / PP200 go into C:\APP\... in statements such as "Dico=thesauGB.dbz" (in file Dico.txt)...
    Please notice that you can have DiagBoX, Lexia and PP2000 eaxh working in a different language...
    PP2000 Language fall back and font sizing
    Also, for PP2000, the statement in C:\APP\OUTILREP\EXE\LANGUE.INI:
    [BackUpDico]
    BackUpThesau=\app\outilrep\Dico\thesauGB.dbz
    will determine the language used in case you choose an unsupported language (or missing language files). In this case you may also add the statement Arial=10 (or any font size that you may prefer) like below.
    [FontScale]
    Arial=10
    p.s. Simple trick, if you wish to play with the font size, change the statement in Dico.TXT "Dico=thesauGB.dbz" to "Dico=thesau.dbz", this will force the system to use the backup language of your choice with the Arial fonts you decided... I tried it for PP2000, and it works.
    Lexia resizing and screen positioning
    And since I am at it, you can also position and resize Lexia on the screen to your liking by navigation to:
    C:\APP\LEXIA\EXE\ and finding the file: "ecran.ini".. open it using notepad and under:
    [GENERAL]
    position_X =0
    position_Y =0
    largeur_ecran = 1024
    hauteur_ecran = 748
    I think it is self explanatory, the X and Y affect positioning on the screen (from top left), and the ones I cant read are the Width and Height in pixels...; Try "position_X =200", "position_Y=100", "largeur_ecran = 800", "hauteur_ecran = 600" and restart Lexia.
    Once again, This is for experimental and educational use and I hold no responsibility for any damage to your system..
    Enjoy the French version of DiagBox 7.xx
Nom : 		DB1.jpg
Taille :		39,4 Ko
Nom : 		DB-777.jpg
Taille :		85,3 Ko
    I have just heard from maitresox that he added a patch to switch to French in his release..
    Simple.
    Dernière modification par Simple, 08 décembre 2015, 18h46.
  • ballajunior
    • juillet 2015
    • 31
    Bonjour tlm,
    Simple m'a demandé si je pouvais traduire son message en français, pour ceux que ça intéresserait. N'hésitez pas à me faire un retour si vous voyez une erreur de traduction ou si vous êtes confrontés à des problèmes particuliers en suivant cette procédure.
    Alors, here we are ;-)
    DiagBox 7.77 (8.13) MAJ
    MAJ du DiagBox de la version v7.76 à v7.77
    Merci de noter que cette procédure a été produite à des fins éducatives et que son utilisation, partielle ou complète, est à vos propres risques. Je (Simple) n’assume aucune responsabilité quant aux éventuelles problèmes vous allez rencontrer suite à cette MAJ.
    Comme pour les autres procédures d’installation, il est préférable de déconnecter votre pare-feu et antivirus.
    Procédure (Offline Update):
    1- Allez dans C:\AWRoot\bin\fi\ et créez un dossier au nom de « cashe.org ».
    2- Téléchargez le fichier "updt_77u.zip" et copiez/coller son contenu (Appli, MAJDIST, Reco, majdist.tmp) directement dans C:\AWRoot\dtwr\updt, qui écrasera et remplacera les anciens dossiers/fichiers.
    3- Démarrez DiagBox. Ensuite, la MAJ s’effectuera et quand elle aura terminé avec succès, cliquez sur « ok ». Normalement, DiagBox devrait redémarrer. Si non, démarrez DiagBox et vous allez obtenir 6 à 7 messages d’erreur la première fois. Cliquez toujours sur « ok », jusqu’à ce que le programme se referme.
    4- Copiez les 13 fichiers qui commencent par « fr.actia.AWF.xxxxxxx.dll » du dossier « cashe.org » dans le dossier (vide) C:\AWRoot\bin\fi\cashe\folder.
    5- Démarrez DiagBox et celui-ci devrait fonctionner parfaitement.
    Si vous n’aimez pas cette MAJ ou que vous avez rencontré des problèmes, refaites à nouveau la MAJ v7.74 à v7.76 de Maitresox et DiagBox devrait revenir correctement à la version v7.76.
    J’ai (Simple) aussi réussi à changer la langue du DiagBox d’anglais à français, pour ceux qui avaient connu ce problème après la MAJ v7.76. Voici la procédure :
    Pour DiagBox:
    1- Ouvrez votre Explorateur de fichiers et cherchez dans "C:\AWRoot\dtrd\trans\" le fichier "Language.ini" et créez une copie au nom de "Language.ini.org".
    2- Ouvrez ensuite le fichier “Language.ini” et sous [LANGUAGE], changez "Current=en_GB" avec "Current=fr_FR" et sauvez. (J’ai mis un commentaire dans l’original et ajouté les changements)
    [LANGUAGE]
    ;Current=en_GB
    Current=fr_FR
    Pour Lexia:
    1- Ouvrez votre Explorateur de fichiers et cherchez dans "C:\APP\LEXIA\EXE\" le fichier "langue.ini" et créez une copie au nom de "langue.ini.org".
    2- Ouvrez ensuite le fichier "langue.ini" et sous [DicoMap], changez tous les "%LG%" en FR (J’ai mis un commentaire dans l’original et ajouté les changements).
    [DicoMap]
    3- Ouvrez votre Explorateur de fichiers et cherchez dans "C:\APPLIC\LCTLEX3\" le fichier "Dico.txt" et créez une copie au nom de "Dico.txt.org".
    4- Ouvrez ensuite le fichier "Dico.txt" et changez la ligne "Dico=THELEXGB.DBZ" par "Dico=THELEXFR.DBZ"
    ;Dico=THELEXGB.DBZ
    Dico=THELEXFR.DBZ
    Pour PP2000:
    1- Ouvrez votre Explorateur de fichiers et cherchez dans "C:\APP\OutilRep\exe\" le fichier "Dico.txt" et créez une copie au nom de "Dico.txt.org".
    2- Ouvrez ensuite le fichier "Dico.txt" et changez la ligne "Dico=THESAUFR.DBZ" par "Dico=THESAU**.DBZ", ou ** est n’importe laquelle des 20 langues disponibles.
    Merci de noter que l’anglais=GB, français=FR et l’allemand=AL (Dénomination française, mais pas Unicode)
    J’ai changé “en_GB” par “fr_FR” dans d’autres endroits de mon système, mais je ne pense pas que vous en ayez besoin. L’explication ci-dessus doit être suffisante pour que cela fonctionne. Si jamais, vous pouvez les trouver dans quelques INI ou fichiers Java….
    Vous pouvez aussi utiliser un script pour changer les “en_GB” en “fr_FR”, mais faites attention, car certaines listes sont définies pour les langues comme l’arabe ou l’allemand etc… Mais si cela ne vous pose pas de problème particulier et que vous n’avez pas besoin d’autres langues, ça devrait fonctionner.
    De nouveau, cette procédure a été produite à des fins éducatives et que son utilisation, partielle ou complète, est à vos propres risques. Je (Simple) ne serai être tenu pour responsable de quelconque dommage qui pourrait survenir en suivant ces procédures.
    • Simple
      • août 2015
      • 253
Nom : 		DB9.jpg
Taille :		46,6 Ko
      The language button problem in DiagBox v7.74+ is now sorted.
      • Simple
        • août 2015
        • 253
        Hi Maxime,
        The v7.77 update is a genuine PSA release downloaded from their site. I did not offer a packaged solution, I detailed the way to do it for people to learn. Of course we are grateful to scarymistake, Louis Andre and maitresox for providing this unlocked software, otherwise the investment would be much greater.
        But I posted the workaround to the French language problem a day after I learnt (from a French user) that people cannot use (v7.74, 7.76 and 7.77) Lexia in French, in fact they cannot change the set language. I did not know about the problem because I only use Lexia in English, which was working.
        Later, maitresox has incorporated the workaround for the "French" language. But (in an other post) he showed the Language button being a problem. I decided to tackle it and resolve it, as you see above..
        To be honest, I hardly use this XS Evolution device, I have a Citroen C8 which I will probably change soon and a Chevrolet Tahoe. But being in IT since the late 1970's (I was back then an Engineer at Digital Equipment Corporation) I find it interesting to solve some issues in my spare time...
        I don't do this for living, I do it for love and to empower users, that's all.
        Thank you again and best regards, Simple.
        ** I have added an Arabic screen shot of PP2000. Notice that it is an RTL (Right To Left) language.
        The translation is probably done by an Alien (from outer space) and if he has done the scripting as well, then he must be in Kindergarten or Senior Infants; at best!!!.. how lovely of him....
        My little son learnt Arabic in Dubai and he found (lots of) mistakes in the text.. Well, let's look at the bright side, he could become friends with this baby alien if they decide to invade Earth..
Nom : 		DB10.png
Taille :		81,0 Ko
        Dernière modification par Simple, 09 novembre 2015, 10h29.
        • fabipk
          • juillet 2014
          • 22
          Muchas gracias, en español funciona?!
          • Simple
            • août 2015
            • 253
            Yes, it works in Spanish.. All 20 languages listed in the country codes table; work (last attachment in the first post with flags)..
            Your codes are.. SP, es, es_ES.
            It can work with some other languages (like Arabic) as demonstrated above, but with more modifications..
            Good Luck. Simple.
            Dernière modification par Simple, 10 novembre 2015, 02h41.
            • fabipk
              • juillet 2014
              • 22
              Yo actualmente tengo instalada la 7,62. me baje el parche para saltar a la 7,66. ahora veré de buscar los enlaces de las actualizaciones necesaria para llegar a esta 7.77.
              Se encuentran en algún mensaje en particular?
              Gracias
              • Simple
                • août 2015
                • 253
                I am not sure I understand the question!! If you are looking for the "updt_77u.zip" upgrade file, please read the first message carefully, use <ctrl + F> to search.
                • flashbax
                  • 40
                  Envoyé par fabipk
                  Gracias
                  No estoy seguro de entender todo pero hay la actualización para saltar a la 7.66 aquí:
                  http://www.lesamisdudiag.com/diagbox...s-offline.html
                  No hay las actualizaciones siguientes -> 7.76 en este foro, hay que buscar en otros foros.
                  (lien pour la maj 7.66 ici, mises à jour suivantes -> 7.76 à chercher sur d'autres forums)
                  • fabipk
                    • juillet 2014
                    • 22
                    Exacto, a eso me refería, a pasar de la 7,62 hasta la actual. voy a buscar los enlaces.
                    Saludos
                    • petit-suisse
                      • 38
                      est-il possible de contourner les telecodages securisés avec cette version?
                      • manu06
                        • 96
                        une fois redémarrer il n'y as rien dans le dossier cache (4- Copiez les 13 fichiers qui commencent par « fr.actia.AWF.xxxxxxx.dll » du dossier « cashe.org » dans le dossier (vide) C:\AWRoot\bin\fi\cashe\folder)
                        • Simple
                          • août 2015
                          • 253
                          Where did you get this "C:\AWRoot\bin\fi\cashe\folder" from??? Have you lost the contents of the "CACHE" folder???
                          If you are already in trouble, download "cashe.rar" which is attached to the first post, expand it and copy the contents to your "cashe" folder. Start DiagBox and it should be working..
                          • jsamii
                            • 29
                            bravo pour la traduction
