XS Evolution VCI Firmware Auto-Update
  • Simple
    • août 2015
    • 253
    Automatically updating XS Evolution VCI Firmware
    To make DiagBox check the VCI firmware and update if necessary some files and setting are needed.
    Precaustion:
    Copy or move all files (NOT folders) inside "C:\AWRoot\bin\Launcher\" to a safe location before performing the following:
    1- Download "Launcher.rar" from the link provided
    2- Extract all files into "C:\AWRoot\bin\Launcher\" skipping or replacing existing files (ap.ini need to be replaced)
    3- Rename your preferred Firmware inside Launcher folder to APPLI.COM
    4- Connect your VCI and wait until it is recognised
    5- Launch DiagBox, it will check the VCI Firmware and update ONLY if necessary.
    You can disable this function by setting "MAJ_COM=TRUE" to "MAJ_COM=FALSE" in ap.ini
    Note: Some users may be afraid that a damaging APPLI.COM may be included in a future update release. It does not matter if this is feasible or not, you can change AP.INI settings to disable firmware update after performing your desired update and put your mind at rest.
    Simple..
    Dernière modification par Simple, 21 juin 2017, 22h32.
  • m0rg4n
    • 211
    Envoyé par Simple
    Precaustion:
    Simple..
    Hi, the Mega link in your .txt file is dead.
    I would like to let Diagbox update my VCI's Firmware. I 've a genuine xs evolution and I would like to use Diagbox 7.82 but my firmware is 4.3.3.
    Thank you for you help.
    • Simple
      • août 2015
      • 253
      The link is NOT dead, it is working fine, I have just tried it. Please ensure you don't have extra spaces or added characters when you use cut and paste, or use a different browser.
        • 713
        • Simple
          • août 2015
          • 253
          I changed the key, try again..
            • 713
            Envoyé par Simple
            OK it works ok sa marche
            • m0rg4n
              • 211
              Envoyé par Simple
              Thanks, it works well.
              • bilouze60
                • 63
                Quel est la dernière version de ce firmware 4.3.? ??
                Merci pour vos réponses.
                Hello,
                what is the last version of this firmware ?? 4.3.?
                Thanks for answers
                  La dernière version du firmware 4.3.4
                  • bilouze60
                    • 63
                    Merci Mecano57
                    Encore une fois....
